TP5 crash
thomas.jud
The TP5 Application crashs without an error report if I open popups with a lot of buttons or elements on it.
Propably there is anywhere a solution or a similar behavior.
I think this is in context with a corportate windows profile, a win service or similar..
Any ideas?
Windows:
Edition Windows 10 Pro
Version 22H2
Betriebssystembuild 19045.3570
TP Design 5:
Version 1.5.0
Build 111
Border Version 25
Support Files 1.5.69
This happens quite a lot if you have big panel designs - it's a bug from G4 that has survived through to G5. It's something to do with the xml corrupting. The only way I have got round it is to copy/paste the offending page (without opening it) and then deleting the old version. The paste seems to rebuild the xml and whatever it is that's corrupted gets reset.
Simon
indeed, that helps!
Somitimes i have to save a popup twice but then is it stable..
Thanks Simon
ups it helps just in a session. If I reopen the file I have the crash again on different popups..
Windows Event
Name der fehlerhaften Anwendung: TPDesign5.exe, Version: 1.5.0.111, Zeitstempel: 0x5b91dd2b
Name des fehlerhaften Moduls: ntdll.dll, Version: 10.0.19041.3570, Zeitstempel: 0xf0fc3229
Ausnahmecode: 0xc0000374
Fehleroffset: 0x000e6c43
ID des fehlerhaften Prozesses: 0x65fc
Startzeit der fehlerhaften Anwendung: 0x01da0347df9d4ee0
Pfad der fehlerhaften Anwendung: C:\Program Files (x86)\AMX Control Disc\TPDesign5\TPDesign5.exe
Pfad des fehlerhaften Moduls: C:\Windows\SYSTEM32\ntdll.dll
Berichtskennung: d94f453c-b741-40db-a611-46300c053e47
Vollständiger Name des fehlerhaften Pakets:
Anwendungs-ID, die relativ zum fehlerhaften Paket ist:
I did a sfc /scannow but noting helps...
Any further ideas?
I think i found a solution:
Right click on TPDesign5.exe -> Properties -> Compatibilty -> Mode Checkbox ON and choose Windows 7
