Home AMX Design Tools
TP5 crash
The TP5 Application crashs without an error report if I open popups with a lot of buttons or elements on it.
Propably there is anywhere a solution or a similar behavior.
I think this is in context with a corportate windows profile, a win service or similar..
Any ideas?
Windows:
Edition Windows 10 Pro
Version 22H2
Betriebssystembuild 19045.3570
TP Design 5:
Version 1.5.0
Build 111
Border Version 25
Support Files 1.5.69
  • sling100sling100 Posts: 123
    This happens quite a lot if you have big panel designs - it's a bug from G4 that has survived through to G5. It's something to do with the xml corrupting. The only way I have got round it is to copy/paste the offending page (without opening it) and then deleting the old version. The paste seems to rebuild the xml and whatever it is that's corrupted gets reset.
    Simon
  • thomas.judthomas.jud Posts: 46
    edited October 2023
    indeed, that helps!
    Somitimes i have to save a popup twice but then is it stable..
    Thanks Simon
    ups it helps just in a session. If I reopen the file I have the crash again on different popups..
    Windows Event
    Name der fehlerhaften Anwendung: TPDesign5.exe, Version: 1.5.0.111, Zeitstempel: 0x5b91dd2b
    Name des fehlerhaften Moduls: ntdll.dll, Version: 10.0.19041.3570, Zeitstempel: 0xf0fc3229
    Ausnahmecode: 0xc0000374
    Fehleroffset: 0x000e6c43
    ID des fehlerhaften Prozesses: 0x65fc
    Startzeit der fehlerhaften Anwendung: 0x01da0347df9d4ee0
    Pfad der fehlerhaften Anwendung: C:\Program Files (x86)\AMX Control Disc\TPDesign5\TPDesign5.exe
    Pfad des fehlerhaften Moduls: C:\Windows\SYSTEM32\ntdll.dll
    Berichtskennung: d94f453c-b741-40db-a611-46300c053e47
    Vollständiger Name des fehlerhaften Pakets:
    Anwendungs-ID, die relativ zum fehlerhaften Paket ist:
    I did a sfc /scannow but noting helps...
    Any further ideas?
  • I think i found a solution:
    Right click on TPDesign5.exe -> Properties -> Compatibilty -> Mode Checkbox ON and choose Windows 7
