Home AMX Control Products
Varia-100 Panel command ^AKB not responding as expected.
I am attempting to use the ^AKB command to adjust button text, however when the Varia panel returns the string it doesn't include the ^AKB prefix. I have also attempted to use a custom prefix but still no joy.
this was my initial attempt:
send_command dvTPa_2, "'^AKB-',uVidSrc[1].sName,';Edit Source Label'"
then I attempted:
send_command dvTPa_2, "'^AKB-',uVidSrc[1].sName,';Edit Source Label;enter input name;VidName-;1'"
Best Answers
  • Marc ScheibeinMarc Scheibein Posts: 973
    Answer ✓
    Confirmed... only the value is returned, not any prefix, neither the ^AKB- nor the optional prefix defined in the command. Same with the legacy @AKB- and AKEYB-
    Firmware 1.11.29.
    Should be reported directly to Technical Support....
  • wilmerswilmers Posts: 2
    Answer ✓
    thanks for confirming, I have email tech support
Answers
  • I also did ;)
  • I got a firmware test build v1.11.31, seems this issue is solved with this build. ^AKB- with its parameters, AKEYB- and even an keyboard opened by panel design will have now the corresponsing prefix.
    So we can expect this fixed in the next regular firmware release.
  • emdx71emdx71 Posts: 51
    PKEYP- is the same way, only returns the value and not KEYP-(VALUE)
