VST Miniverter ICSNet controls?
I have a project with 9 VST thermostats (Miniverter ICSNet version) and 13 Modero panels and I am not sure how to setup my code to control all of them or what is the best way at least.
All 13 Modero panels need to control all 9 thermostats. The current AMX VST ICSNet module can handle all 9 VSTs without a problem, but since it uses Zone variables it can be a problem when more than one panel is accessing the module at the same time. For example, I select zone 1 and another panel zone 2, when I send a command it goes to zone 2 instead of 1, since 2 was the last zone selected.
Should I assign each thermostat to a single port and define 1 UI and 1 Comm per thermostat. Essentialy, I would end up with 9 UI definitions and 9 comm module definitions. Then I would use DEFINE_COMBINE to combine all physical Moderos to a virtual panel per UI, Like this:
Or maybe I shoud creat one UI per Touch Panel and each UI uses the 9 VST zones. Do I need to define 9 comm modules here as weel?
Any help here will be very appreciated. I know that some of you have used the 422/dist board combination, but in my case everything is ICSNet. Next year I have a job with 38 VSTs and probably 30+ Moderos, I just want to start on the right direction. Also, I want to make sure that the Netlinx Processor don't lock up. Any ideas?
Ricardo
DEFINE_COMBINE //Stat1(Using Port 1 on Tps): (vTP_STAT1, dvTP_10001,dvTP_10002, ... dvTP_10013) //Stat2(Using Port 2 on Tps): (vTP_STAT2, dvTP_10001,dvTP_10002, ... dvTP_10013) . . . //Stat13(Using Port 13 on Tps): (vTP_STAT13, dvTP_10001,dvTP_10002, ... dvTP_10013)
Ricardo
Currently have running 11 Viewstats with ICSNet on an inherited job, not sure why board was not used.
Another job a master (1) running code with two ICSNet stats into ICSNet ports, then master 2 has a third stat connected. Master 1 code simply refers to stat 3 at 10403:1:2. Works fine.
Would love to hear experience and results for the upcoming job when completed. I suspect those stats will end up being Ethernet.
(Gazes longingly toward the heavens, "802.11g thermostats...Mmmmm...")
Bill
The whole idea is to prevent conflict when all panels are accessing the same UI. In other words, I would like to have each panel controlling the 9 stats independently. In Addition, I wonder what is the most efficient way to handle this. Any suggestions?
Ricardo
Keep in mind, this is the approach I used with the 422 interface using the netlinx module for Aprilaire (viewstat) devices. I am just now starting to look at the new java module and so far it looks like I'll be able to do the same thing with less code work on my end do to the way the new module handles feedback.
Hope this helps,
