NI3000 Duet Firmware - Dead HTTP Server
in AMX Hardware
Hi, I have upgraded to the latest DUET firmware, my http server is now dead (see attached screenshot). I am not using any duet modules and have set the duet memory to 4Mb as per a few posts I have seen.
Any idea where I need to look for this?
- If you do a "show mem" (w/o "") in Terminal, what memory sizes would you get?
- Will the webserver work if you disable the runmode (Dipswitch 1 on the back to ON, reboot)?
- What browser do you use?
Regards,
Your last question was the most important, I was accessing via my mac using safari. I have just used a PC with IE and all looks ok.
Is the netlinx web interface ie only?
Working on M$ Systems only....
In general, I prefer Opera, but Opera is not supporting XML and SXL based pages (like the Duet webserver uses)
