Controller and TP have different times.
Thomas Hayes
in AMX Hardware
Hello everyone
Please correct me if I am wrong but should the TP not reflect the controllers time after I do a 'set time/date' in Studio? My controller show the time I set it to but the panel is off.
Here's a question though: did you disable UDP broadcasts from the master? That's where it gets the time from (I've seen the broadcst go out while packet sniffing for other issues), so if you disabled it, no update.
DEFINE_PROGRAM wait(600){ // do every minute SEND_COMMAND dvTP, "'@TXT',TXT_HOME_TIME,TIME" } }You could do something like this in your program. Your controller's time and your TP's time will always be within a minute of each other.
Jeff Lockyear
Synergy Home Systems, Toronto
