MVP8400 and camera images
Does anyone know of a IP camera server that also serves jpg images?
Thanks!
Thanks!
i am using a Axis ip video server. it takes composite in.
the model i am using is a one video source device, but multiple inputs are possible on other models. you would need to program it over http to control input selection.
when i can, i will chase down the model details, it's onsite at customer's house.
i then use it for jpeg motion feed, setting the panel to read the stream every 0.5 secs or so. it will also feed as jpeg still images.
this works reasonably well, the device is roughly $300 Australian.
some limitations are...
it will not supply an image greater then 320x240. i guess it would be quite a bit of data going much larger.
i need to check, but i wonder if the stream is continuing to feed, even when the panel has stopped viewing it. (not so much a server issue but a panel issue).
and now i am about to test a Taiwanese MPEG4 Video server. (SED-2100S). will provide an update once that is done.
i tried the Taiwanese MPEG4 Video server. (SED-2100S).
they also has a variant in the form of a Day/Night Camera.
but i can't get anything from it to the panels. it's MPEG4.
and requires an ActiveX component in IE.
so not much good to us. i wonder if i missed something, is there a way to stream MPEG4 to wireless panels, anyone ?
and thanks for the dynamo reminder. will revisit that for the motion jpeg on the Axis system.
oh ok, dynamo is dynamic image with refresh rate set to zero.
simple enough. i was looking for a some kind of option to set
been using these with pretty decent results. Here at our office I used one to display the gui for a kaleidescape and control it via x,y pushes. really works slick!
also awhile back I posted the path here:
http://hostname.or.ip/axis-cgi/mjpg/video.cgi
The video server will be used only inside a local network out of a Autopatch output.
Ricardo
Ricardo
To set up the video, create a dynamic image with the appropriate data from your Axis server - URL to the server, login, parameters for the picture size. As I recall, I had no trouble finding what I needed in the Axis interface to populate the TPD4 forms for the dynamic image. It runs something like this:
Protocol = HTTP
Host = xxx.xxx.xxx.xxx:yyyy (IP port of server, as per your setup)
Path = axis-cgi/mjpg
File = video.cgi?resolution=4CIF&camera=1 (4CIF is the large view, just CIF is 1/4 size, camera number for multiple input boxes)
user/password: as per your setup
Ricardo
it's Anzac Bridge, Sydney Australia.
create a dynamic image with the following settings..
protocol: http
host: rta.nsw.gov.au
path: trafficreports/cameras/camera_images
file: 034.jpg
leave user name and password blank.
set refresh rate for 1800 (3 minutes) (go less if you like)
you will then see the closest bridge to my part of the world.
apparently, if the source is a motion jpeg (this example isn't), you can set the refresh rate to zero and be able to receive the video stream at the fastest available frame rate.
there are many more cameras around the world that can be hooked in the dynamic image. whereever you find a webcam, try to get the full address by right-clicking on the image and select properties. then select and copy the address into an editor, and break it up into the required options for dynamic images.
Looks pretty quiet at 3 AM your time.
I've done that right click -> properties thing to get dynamic weather maps and cam servers on modero panels before - it's fun. In fact, I think that's one of the first things I did when we got our TPI4 demo unit. (The first G4 device my company got to actually play with)
Protocol = HTTP
Host = 192.168.1.113:???? - I am not sure of the Port Number or how to configure one or even if I need one?????
File = video.cgi?resolution=2CIFEXP
Any Ideas on what am I missing or where I can see the port number or use the default one? Thanks,
Ricardo
Protocol = HTTP
File = video.cgi?resolution=2CIFEXP&camera=1
Refresh = 1 (*Note: with refresh 0 image was freezing after a while or when I went from one dynamo image to another)
Now, what is the best compression and frames/second to set the Axis to? I am using:
Resolution = 2CIFEXP (* 704x480 rescaled on server side - 4CIF was to high)
Compression = 50 (* Still shows a decent image)
Frames/s = 10 (* I noticed that the b wireless protocol limits the MVP8400 ability to render anything better than 15 frames/s on a 704x480. Hopefully there will be a G wireless upgrade in the future)
Any suggestions to improve?Thanks.
Ricardo
i would suggest that you can never expect more than 15 frames per second from all but the highest-end product. i wouldn't expect much more would be achievable from jpeg/motion jpeg.
would be glad to hear from anyone who can get it smoother/faster.
The axis are about $1k each as I recall, which is too steep for what we've got going...though I did see this Lorex recently. Can someone who's more clued in than me take a look at the specs? I'd appreciate a quick take on whether this'd work to feed vid to an MVP via dymo.
They've got a spec sheet and manual in pdf at the link below.
http://lorexstore.strategicvista.com/product.aspx?id=825&nav=3
Thanks in advance for any guidance.
-Bill
1) Only 2 resolution settings: 640 x 480 and 320 x 240
Note: You won't be able to fill the screen on a Modero panel with 800 x 600 and up. But you can't do that with the Axis either 704 x 480
2) It uses its proprietary software to manage the video server versus a regular web browser like the Axis.
However, the price is very good for a 2 channel video server. If you can get it from a store that accepts returns in case you are not satisfied, this may be a good alternative to the Axis. But without testing it and looking at the image quality, it is hard to recommend. One good thing about the Axis server is the ability to tweak the image quality and use different resolutions.
Sincerely,
Ricardo
for dynamic images to work in the MVP, the video server needs to put out jpeg images. then, within the dynamic image definition of the panel, set the refresh rate to zero (0). the image will then update whenever a new jpeg image is ready. this can give you roughly 15 frames per second of dynamic jpeg, depending on the video server and overhead.
bascially, if you cannot browse to a jpeg image from you pc (without using java or software) then the video server will not support the MVP.
here is an example of typing in the web address. ...
http://rta.nsw.gov.au/trafficreports/cameras/camera_images/305.jpg
note the line ends with FILENAME.jpg .. that's what is needed.
