can not receive axcent3 code
in AMX Hardware
hi,
i am trying to download code on axcent3 controller using netlinux studio V2
when i start to receive code it transfer just 1024k and i got this error
status failed
attached is screen shoot from error
help please
status failed
help please
I am curious, are you able to see the master and devices
in your online tree in NS2?
Possibly your comm settings are not correct.
thanks for your replay how i can see the master and devices
If you are communicating properly:
Typically,you will see the communication box (screen lower right)
colored green and displaying the current parameters.
(Although sometimes this box is green even when parameters
are not correct).
On the left side of the screen in your workspace area,
you will have 2 tabs to choose from.
Select the "online tree" tab,
click on the small box labeled "display",
then select "refresh system".
The workspace section should display the associated master,
and also list the devices connected and their firmware versions.
Make sure that you are using the same communication parameters
to transfer files as you are for master communication.
When you attempt to transfer, make sure the listed connection
settings match.
thanks i do as u say and i got list of devices connected to axcent after that i try to receive code again and still the same error
but i notice a strange error source code required password or password is invalid so is there any suggestion
It sounds like the vendor who previously loaded the program
has password-protected the code.
Unless you have the proper password to extract the data,
I believe you may be out of options for receiving the code.
I am not aware of any backdoor path into these units.
thanks for fast replay , suppose that i can got the password where i can put it to complete receive all code
ahmed
it does not prompt me for user name or password when i try to receive code from controller
is there any way to get the code
ahmed
If it is no source code available it is becouse the previous tech uploaded machine code only. It was actually very common not to upload the source code on axcent 2/3 due to the memory limitations of the masters.
