Wireless master
in AMX Hardware
Has anyone ever used an NI master wirelessly? I have an installation that needs a master where there is no Cat5 for a network connection so they want to plug the master into a wireless bridge instead. There will also be a wireless MVP-8400 and a wired CV12.
Has anyone ever had a positive experience with a wireless master? I tried calling tech support but they are closed for the holiday.
Thanks.
Thanks.
The real reason I am posting tho is because of a moment of clarity. I really like the hidden meaning of your signature graphic... AMX ROCKS!
Also - wired to the theater router is another wireless router (Family Room) to which is wired another controller and receiving wireless MVP (Family Rm).
I was originally going to do it all "properly" with separate access points and switches, but all I had initially was the wireless routers, and they worked.
Client's original wireless router was Linksys, so I used all Linksys.
I could sketch it and detail it in an email if you want; if you have time to source APs and switches, that might be easier (although you will need 2 APs each location, one for receiving MVP and one for wireless bridge).
Bill
Thanks. I wondered if anyone understood the graphic. I asked my wife to tell me what she thought it meant. She looked at it for a while and replied, ?AMX Stones?? :eek:
Another product I have used in tough-to-wire spots is the Netgear powerline ethernet adapters. You plug the transmitter in at your router, and can pick up the network anywhere there is an electrical outlet with one of the receivers. They make a hard-wired receiver, and a WAP receiver that takes the powerline signal and broadcasts it as an independant WAP. Very useful set of tools for retro jobs.
It might have to do with the fact it was a model made for 240vAC but the advertised speed was nowhere near what I got for real.
I did notice that one factor was with the other equipment connected to the power circuits, so when installing it into a house, you should consider the potential for "dirty" gear to be on the same line.
Performance-wise, they are limited to 10 Mbs. - more than good enough for AMX communications, or even your typical broadband, but I wouldn't want to connect to my server with it. I imagine a noisy electrical system will affect performance as well.
