Error message
                    Hi
Earlier I posted in duet forum ( and delete the post) concerning problem with duet module and netlinx, because I believed as they are not compatible. ( Error message as I got when I transfered files )
To do a test , I did a small system with the same devices in Visual Architect and I got this error message when I build the code
Why ?
---- Starting NetLinx Compile - Version[2.3.0.0] [05-01-2006 15:14:43] ----
ERROR: C:\Documents and Settings\Denis\Desktop\test\test\Source\test.tko(0): L20218: Missing valid AMX module reference for [Marantz_SR8500_Comm_dr1_0_1.jar]
C:\Documents and Settings\Denis\Desktop\test\test\Source\test.axs - 1 error(s), 0 warning(s)
NetLinx Compile Complete [05-01-2006 15:15:38]
Why ?
Please check if the file is in
c:\Program Files\Common Files\AMXShare\Duet\module
Please also check this path in VA
Menu MANAGERS -> DEVICE DATABASE MANAGER
Are the paths correct?
Kind regards,
It looks like it was a module problem. Try downloading the new version from the AMX website and let me know if you have any more problems.
Hope this helps,
Marji
