AXB-NET PC Server example
Attached is example server software for demonstrating communication between an AXB-NET and PC. This software emulates an AXB-NET in server mode.
Example useage from a Windows command prompt:
axb-net_server -i:10.0.0.1
If you don't include ip address it will pick the first Ethernet adaptor.
It listens for incoming connections and print out the communications exchange. This example is limited to five AXB-NET clients.
If you are interested in controlling an Axlink bus via AXB-NET from a PC/Mac/or Linux drop me an email so we might discuss your software needs.
Note: AXB-NET is a discontinued product. Units can often be found on ebay.
Joel Winarske
joelw at indyelectronics dot com
Joel Winarske
I got one of these wanting to try controling AMX with a web page. I got all the server software, and was able to get it communicating between the AXB-NET and the PC, but couldn't get it to do anything more. I created a touch panel in TPDesign 3 and exported it as HTML using the right IP address and such, but nothing.
Do I actually have to go through and manually code everything to work with Weblinx?
Ryan
Hi Ryan,
Be sure to read this document: http://www.amx.com/techdocs/0532158.pdf
If you're looking for Weblinx help please post a fresh thread.
