Java Issues
Im trying to pull up a web page that my designer designed for me. I think my Java installation is too new and I am having problems finding a correct non corrupt download
The message I am getting on the java console is
getDefault, waiting, this = com.amx.wdm.netWebDeviceRegistry@747fa2
On the actual page I am getting this
Loading class com.amx.wdm.net WebDevicesRegistry$infoTable
It hangs there.
This is version Java (TM) Plug In Version 1.4.0_03
I do have other downloads of 1.4.0_02 but they all seem corrupted.
It hangs there.
http://java.sun.com/j2se/1.4.2/download.html
Please also check that TPDesign3 has Version 3.16 Build 200. If not, please update TPDesign3 and convert and download the pages again.
If you use Duet firmware in the master, it's recommended to enlarge the memory reserved for Duet to minimum 5MB:
The following is part of a terminal session:
I hope this will help.
Kind regards,
- Does the Java Panel have an unique address on the bus? Some weeks ago I got nuts because my java panel won't start, and at the end I found that I had used the same bus address for the java applet and for a real panel.
- While loading the applet is over IP port 80, the communicatiom between the applet and the master is on IP port 10500.
It was a port forwarding issue. Nothing to do with all the variations of java. Whats strange is that some computers could connect and some could not....
But now all working.
Thanks for all your help
It is possible to run both the newest version of Java, and the old (for G3 web control compatibility) at the same time. The trick is to have the newest version installed, and then install the old 1.4.2_07. They will run in conjunction then. What you do NOT want to do is have the old, and install the newest. Doing that will overwrite the old.
We also have absolutely good experience with JRE v1.4.2_10 to _12 . From _10, there is a fellable speedup in launching the aplett.
