RSS Feeds
Binu
Dear experts can any one post an example source code for using the RSS feeds and retrieving data from this feeds (for example Rss feed from the AMX web site for their latest firm ware updates)
PROGRAM_NAME='Weather'
(* FILE CREATED ON: 06/12/2006 AT: 09:45:39 *)
(* FILE_LAST_MODIFIED_ON: 06/16/2006 AT: 14:01:21 *)
(* DEVICE NUMBER DEFINITIONS GO BELOW *)
dvRSS = 0:3:0
vdv_KP = vdv_KP2 //from master
(* CONSTANT DEFINITIONS GO BELOW *)
DEFINE_CONSTANT
LINE1 = 301
LINE2 = 302
LINE3 = 303
LINE4 = 304
LINE5 = 305
LINE6 = 306
(* VARIABLE DEFINITIONS GO BELOW *)
define_variable
char strPage[255]
char buff_RSS[42048]
char curr_buff[42048]
char curr_item[42048]
char curr_item_temp[10][42048]
(* STARTUP CODE GOES BELOW *)
define_start
create_buffer dvRSS, buff_RSS
(* SUBROUTINE/FUNCTION DEFINITIONS GO BELOW *)
(* NAME: OnIP_Error *)
define_call 'OnIP_Error' (SLONG nErrorCode, char strSite[])
switch(nErrorCode)
case 1 : send_string 0, "'IP Connect Error (',strSite,'): invalid server address'"
case 2 : send_string 0, "'IP Connect Error (',strSite,'): invalid server port'"
case 3 : send_string 0, "'IP Connect Error (',strSite,'): invalid value for Protocol'"
case 4 : send_string 0, "'IP Connect Error (',strSite,'): unable to open communication port with server'"
case 6 : send_string 0, "'IP Connect Error (',strSite,'): Connection refused'"
case 7 : send_string 0, "'IP Connect Error (',strSite,'): Connection timed out'"
case 8 : send_string 0, "'IP Connect Error (',strSite,'): Unknown connection error'"
case 9 : send_string 0, "'IP Connect Error (',strSite,'): Already closed'"
case 10 : send_string 0, "'IP Connect Error (',strSite,'): Binding error'"
case 11 : send_string 0, "'IP Connect Error (',strSite,'): Listening error'"
case 14 : send_string 0, "'IP Connect Error (',strSite,'): Local port already used'"
case 15 : send_string 0, "'IP Connect Error (',strSite,'): UDP socket already listening'"
case 16 : send_string 0, "'IP Connect Error (',strSite,'): Too many open sockets'"
(* NAME: get_ip *)
define_function get_ip(integer intPort, char strSite[], char strBuffer[])
local_var slong nError
strBuffer = ''
ip_client_close(intPort)
nError = ip_client_open(intPort, strSite, 80, 1)
if(nError) call 'OnIP_Error' (nError, strSite)
(* NAME: parse_xml_for *)
define_function char[42048] parse_xml_for (char xml_string[42048], char xml_value[42048])
local_var char strReturn[42048]
local_var integer pos_start
local_var integer pos_end
pos_start = find_string(xml_string,"'<',xml_value,'>'",1)
pos_start = pos_start + length_string(xml_value) + 2
pos_end = find_string(xml_string,"'</',xml_value,'>'",1)
pos_end = pos_end - pos_start
strReturn = mid_string(xml_string, pos_start, pos_end)
send_string 0, "'xml_value(',xml_value,')=',strReturn"
return strReturn
(* NAME: parse_xml_for_unclosed *)
define_function char[42048] parse_xml_for_unclosed (char xml_string[42048], char xml_value[42048])
pos_start = find_string(xml_string, "'<', xml_value", 1)
pos_end = find_string(xml_string, "'/>'", pos_start)
strReturn = mid_string(xml_string, pos_start, (pos_end - pos_start))
send_string 0, "'xml_value(', xml_value, ')=', strReturn"
return strReturn
(* NAME: ParseStringFor *)
define_function char[42048] ParseStringFor (char str_string[42048], char str_value[42048])
pos_start = find_string(str_string, str_value, 1)
pos_start = pos_start + length_string(str_value) + 2
pos_end = find_string(str_string, "'"'", pos_start)
strReturn = mid_string(str_string, pos_start, (pos_end - pos_start))
send_string 0, "'str_value(', str_value, ')=', strReturn"
return strReturn
(* NAME: FixDayOfWeek *)
define_function char[25] FixDayOfWeek (char strValue[25])
switch(strValue)
case 'Sun': strReturn = 'Sunday'
case 'Mon': strReturn = 'Monday'
case 'Tue': strReturn = 'Tuesday'
case 'Wed': strReturn = 'Wednesday'
case 'Thu': strReturn = 'Thursday'
case 'Fri': strReturn = 'Friday'
case 'Sat': strReturn = 'Saturday'
send_string 0, "'FixDayOfWeek(', strValue, ') = ', strReturn"
return strReturn
(* NAME: display_rss *)
define_function display_rss(integer nItems)
local_var integer nItemCount
local_var char strTimeDate[50]
local_var char strData[255]
local_var char strDay[50]
local_var char strDesc[50]
local_var char strTemps[50]
curr_buff = buff_RSS
strData = parse_xml_for_unclosed(curr_buff, 'yweather:condition')
remove_string(curr_buff, strData, 1)
if(time_to_hour(time) >= 13)
strTimeDate = itoa(time_to_hour(time) - 12)
else
strTimeDate = itoa(time_to_hour(time))
if(time_to_hour(time) >= 12)
strTimeDate = "strTimeDate, ':', itoa(time_to_minute(time)), 'pm'"
else
strTimeDate = "strTimeDate, ':', itoa(time_to_minute(time)), 'am'"
strTimeDate = "itoa(date_to_month(date)), '/', itoa(date_to_day(date)), ' - ', strTimeDate"
send_command vdv_KP, "'TEXT', itoa(LINE1), '-%SF%JC', 'Last update:| ', strTimeDate"
strData = parse_xml_for_unclosed(curr_buff, 'yweather:forecast')
strDay = FixDayOfWeek(ParseStringFor(strData, 'day'))
strDesc = ParseStringFor(strData, 'text')
strTemps = "'low ', ParseStringFor(strData, 'low'), ' high ', ParseStringFor(strData, 'high')"
send_command vdv_KP, "'TEXT', itoa(LINE2), '-%LF%JC', strDay"
send_command vdv_KP, "'TEXT', itoa(LINE3), '-%SF%JC', strDesc, '|', strTemps"
send_command vdv_KP, "'TEXT', itoa(LINE4), '-%LF%JC', strDay"
send_command vdv_KP, "'TEXT', itoa(LINE5), '-%SF%JC', strDesc, '|', strTemps"
send_command vdv_KP, "'TEXT', itoa(LINE6), '-'"
send_command vdv_KP, "'PAGE-(CURRENT)'" //to refresh new text
(* NAME: string_replace *)
define_function char[42048] string_replace(char strBuff[42048],char strFind[],char strReplace[])
local_var char strLeft[50000]
local_var char strRight[50000]
pos = find_string(strBuff, strFind, 1)
while(pos <> 0)
strLeft = left_string(strBuff, (pos - 1))
send_string 0, "'strLeft=', strLeft"
strRight = right_string(strBuff, (length_string(strBuff) - (pos + length_string(strFind) - 1)))
send_string 0, "'strRight=', strRight"
strBuff = "strLeft, strReplace, strRight" //build the string back up
return strBuff
(* NAME: clean_up_output *)
define_function char[42048] clean_up_output(char strSTR[42048])
strSTR = string_replace(strSTR, ''', '''')
strSTR = string_replace(strSTR, '"', '''')
strSTR = string_replace(strSTR, '&', '&')
strSTR = string_replace(strSTR, '?', '-')
//add new ones here as necessary
return strSTR
(* EVENTS GO BELOW *)
define_event
data_event [dvRSS]
online:
send_string 0, 'dvRSS is ONLINE'
send_string dvRSS, "'GET ', strPage, ' HTTP/1.0', 13, 10, 'Connection: Close', 13, 10, 13, 10"
offline:
send_string 0, 'dvRSS is OFFLINE'
display_rss(4)
string:
(* do not remove me! *)
//send_string 0, 'dvRSS is STRING'
//send_string 0, data.text
button_event[vdv_KP, KP_WEATHER]
push:
send_string 0, 'push'
get_ip(dvRSS.PORT, "'xml.weather.yahoo.com'", buff_RSS)
strPage = 'http://xml.weather.yahoo.com/forecastrss?p=46236'
Here's one I created last week. Reasonbly complete and ready for mutliple cities. I didn't get to any TP buttons or feedback but this will get you all the values and you can figure out the rest from there. I haven't tested this fully because of other problems that have distracted me from continuing it. It's neat and clean and ready to go and will get you 99% of the way there.
Enjoy! Hopefully it will saves you from some of the misery that I've been through.
OK, here's the neat version without some constants commented out.
VAV - your posts do not have attachments - am I missing something?
Bill
