NXM-DMP Internet Digital Media Processor
mush
in AMX Hardware
G'day,
I have in my possesion an AMX NXM-DMP.
Does anybody have any information at all about this device?
There is nothing at all about this device on the AMX site???
The device boots up into a black screen. It is running Windows 98 with the only app running being 'ICSP3'.
This is what I know so far from my internet searches.
NXM-DMP
NetLinx Digital Media Processor
* Operates under NetLinx and WebLinx control via ICSP IP commands
* Decodes ASX, ASF, MPEG1, MP3 and other audio and video streams
* Stereo audio output
* Composite NTSC and S-video outputs, PAL output optional
* VGA video output
* 10/100baseT Ethernet connection
Front Panel
Program: DB-9 male connector for RS-232
Power: Green LED indicates power status
Audio: Red LED turns on when audio file is playing
Video: Red LED turns on when video file is playing
Rear Panel
S-Video: S-Video output
Video: Phono NTSC video output
Audio Out: Phono stereo line-level output
VGA: HD15 VGA video output, up to 1024 x 768 True Color graphics
Ethernet: RJ-45 jack for 10/100baseT network connection
Activity: Yellow LED blinks when receiving Ethernet data packets
Link: Green LED blinks when receiving
Speed: Green LED lights when transmitting at 100 Mbps, off when operating at 10 Mbps
PWR: 2-pin 12 VDC power terminal
ICSP: Green LED flashes on presence of ICSP data
ID: Button sets device ID
Dimensions (HWD): 2.06" x 17.0" x 10.37" (52 mm x 432 mm x 263 mm)
Weight: 7.0 lbs (3.2 kg)
Power: 12 VDC
Includes
Rack-mount brackets, adapt for rack, wall, or shelf mounting
NetLinx faceplate
Options: 12 VDC power supply
Any extra help or information or software would be much appreciated.
Cheers
NXM-DMP
* VGA video output
Front Panel
Rear Panel
Power: 12 VDC
Includes
NetLinx faceplate
Cheers
All you can do is recycle PC for something else, it was not a very powerful PC, it used a non Intel processor and had only 256M of RAM if I remember well, and 40Go of HD.
Hope it helps
Vinc
Obviously this product came with some modules and instructions.
Does anybody have anything lying around still?
Due to my love of all things AMX I'm really keen to have a play with this device
and see what AMX (Panja) were up too.
Any help or input would be REALLY appreciated.
Cheers
Unhappy for you you won't find any documentations concerning that product as it was only loaned in Panja 1000 kit furnished by AMX ready to use, and that product has never been sold alone for programmation by anyone So I don't think you'll find anything about it lying around. All the more that product is really old and outdated now, and unless you would find some documentations to control it, you would be able to do very few things interesting with it as all videos and audio codecs managed by that product are probably completely outdated
Vinc
Thanks Yuri, but I already had that info from 'Software History'.
I really just need something from some one who bought one or still has one!!
Ahh... the wonderful Panja system.
There is quite a lengthy story behind this device.
I have a PDF of the manual, but I dont know if it is too big to post.
I will try.
