Intercom?
in AMX Hardware
Ok, doing a search it seems the fabled intercom comes up every year or so, it seemed we are due
So is the intercom 100% analog? Basically it comes through on the breakout box and that is the extent of it? The MVP series have speakers and a microphone but they don't actually "go" anywhere?
I am curious if there is a future where the intercom could be more a VOIP approach (like Netstreams DigiLinX) ~ this would solve the wireless and MVP series being able to play with the others, but if internally it is 100% analog it won't really help!
Just curious if anyone actually uses this or not. Looking at a residential application as opposed to using telephones for basic intercom...
Curt
Trikin
Curt
Trikin
AFAIK at Cedia there would come some news about that.
Is there a solution for the MVP ?
the unit has mic and speaker, but can we use for intercom?
We have 70 CV7s and it would be nice if user could intercom us via audio stream at a centeral location. Are there any examples out there? All CV7 are on a secured network. I have seen no information out there at all about the Intercom. Have any sites, examples, references at all?
Unfortunately, there's no way intercom could be streamed from the panel. CV-7 and other Modero panels have only analogue intercom. Signal from panel's internal mic could be routed back to equipment rack and connected to any audio switcher (balanced or unbalanced) if you use NXA-AVB/Ethernet. As for MVP-8400 - it's seems intercom would not be available for this panel due to some design limitations.
