Nxc-vol4
Hi guys
I'm working with a VOL4 device and experiencing a strange behaviour.
I've used 4 bars to control the volume levels as you can see from the image attached.
Sometimes the bars stop showing the current volume and start to behave like a vu-meter: level values go up and down without any evident reason!
Here is some code
vVOLUME		=	33003:1:0
MIXER_CH1	=	32001:1:1
MIXER_CH2	=	32001:2:1
// used to store volume levels when power goes down
PERSISTENT INTEGER MIXER_VOLUMES[4]
// used to store current volume levels
INTEGER MIXER_VAL[4]
DEFINE_CONNECT_LEVEL
(vVOLUME,1,vTP2,2,MIXER_CH1,1)
(vVOLUME,2,vTP2,3,MIXER_CH1,2)
(vVOLUME,3,vTP2,4,MIXER_CH2,1)
(vVOLUME,4,vTP2,5,MIXER_CH2,2)
CREATE_LEVEL MIXER_CH1,1,MIXER_VAL[1]
CREATE_LEVEL MIXER_CH1,2,MIXER_VAL[2]
CREATE_LEVEL MIXER_CH2,1,MIXER_VAL[3]
CREATE_LEVEL MIXER_CH2,2,MIXER_VAL[4]
SEND_LEVEL vVOLUME,0,MIXER_VOLUMES[1]
SEND_LEVEL vVOLUME,1,MIXER_VOLUMES[2]
SEND_LEVEL vVOLUME,2,MIXER_VOLUMES[3]
SEND_LEVEL vVOLUME,3,MIXER_VOLUMES[4]
// volume +
BUTTON_EVENT[vTP2,180]
BUTTON_EVENT[vTP2,181]
BUTTON_EVENT[vTP2,182]
BUTTON_EVENT[vTP2,183]
	LOCAL_VAR INTEGER SELECTED_CH
	//  [1..4]
	SELECTED_CH = (BUTTON.INPUT.CHANNEL%180)+1
	IF(MIXER_VAL[SELECTED_CH] < 255)
	    SEND_LEVEL vVOLUME,SELECTED_CH,MIXER_VAL[SELECTED_CH]+1
	    MIXER_VOLUMES[SELECTED_CH] = MIXER_VAL[SELECTED_CH]
	[vTP2,188+SELECTED_CH-1] = FALSE // mute off
// VOLUME-
BUTTON_EVENT[vTP2,184]
BUTTON_EVENT[vTP2,185]
BUTTON_EVENT[vTP2,186]
BUTTON_EVENT[vTP2,187]
	// [1..4]
	SELECTED_CH = (BUTTON.INPUT.CHANNEL%184)+1
	IF(MIXER_VAL[SELECTED_CH] > 0)
	    SEND_LEVEL vVOLUME,SELECTED_CH,MIXER_VAL[SELECTED_CH]-1
// MUTE on
BUTTON_EVENT[vTP2,188]
BUTTON_EVENT[vTP2,189]
BUTTON_EVENT[vTP2,190]
BUTTON_EVENT[vTP2,191]
	// [1..4]
	SELECTED_CH = (BUTTON.INPUT.CHANNEL%188)+1
	SEND_LEVEL vVOLUME,SELECTED_CH,0
	MIXER_VOLUMES[SELECTED_CH] = 0
	[vTP2,187+SELECTED_CH] = TRUE
// LEVEL_EVENT PER MIXER VOLUME
LEVEL_EVENT[vTP2,2]
LEVEL_EVENT[vTP2,3]
LEVEL_EVENT[vTP2,4]
LEVEL_EVENT[vTP2,5]
    SEND_LEVEL vVOLUME,LEVEL.INPUT.LEVEL-1,LEVEL.VALUE
    //SEND_STRING 0:1:0,"'LEVEL.INPUT.LEVEL=',ITOA(LEVEL.INPUT.LEVEL)"
    //SEND_STRING 0:1:0,"'LEVEL.VALUE=',ITOA(LEVEL.VALUE)"
    MIXER_VOLUMES[LEVEL.INPUT.LEVEL-1] = LEVEL.VALUE
    IF(LEVEL.VALUE > 0)
	[vTP2,188+LEVEL.INPUT.LEVEL-2] = FALSE
    ELSE
	[vTP2,188+LEVEL.INPUT.LEVEL-2] = TRUE
Any hint?
  • No help?
    Have i been clear enough?
  • I have had this problem before but with a XAP800 as the source from where I was getting my level information.
    I have never experienced it with an AMX Vol Controller.
    My problem was the the processor was parsing the data from the XAP and was getting stuck in a kind of loop. The only way to fix it was to go to a "fake feedback" setup and then just update the XAP blindly. It doesn't help that when a panel goes offline any combined levels go to zero. It would help if they would just stay where they are currently at and then update once the panel comes back online, I feel this is an AMX design flaw in G4 panels.
  • In your code snippet above, in your DEFINE_START
    you are sending the level to level 0,1,2,3
    and in your code above that you are using levels 1,2,3,4
    that seems incorrect to me
    also,
    in your button events below that, I think you should use
    (BUTTON.INPUT.CHANNEL-179) and remove the +1, instead of
    its less for the processor to do and its more definitive, IMO
  • If you can give me a tp file with just that volume page you linked above I can show you a much easier way that you can handle this data in a G4 TP.
  • JustinC, i'm not using g4 touchpanel. Unfortunately my customer wants to use a web interface >>TPD3 html saveas option...
    You were right in your first post: in define_start i use 0,1,2,3 while in my button_event i use 1,2,3,4
    I also think that here:
    LEVEL_EVENT[vTP2,2]
    LEVEL_EVENT[vTP2,3]
    LEVEL_EVENT[vTP2,4]
    LEVEL_EVENT[vTP2,5]
        // probabilemnte non serve!!!!
        // con define_connect_level ho gi? l'associazione
        IF(LEVEL.VALUE > 0)
        ELSE
    this line is superflous:
    the level is automatically updated...isn't it?
    Thanks for your patience
  • Whenever you do the define_connect_level, the processor automatically keeps everything updated. So I believe you are correct when it comes to that line being superfluous
