Transfer Aborted - Firmware ID is invalid
 joelw
joelw
                                  in AMX Hardware
                    I'm attempting to load most recent firmware into a ME260-64 running v2.31.137.
2010-64_ME260-64_Master_v3_12_335.kit
Right when the first file should be sent I get a dialog box stating:
"Transfer Aborted - Firmware ID is invalid"
Is there a way around this?
Great, Thanks!
I did this - update to 139 - and still get that same message "ID Invalid". Any other suggestion?
>show device 0 Local devices for system #3 (This System) ---------------------------------------------------------------------------- Device (ID)Model (ID)Mfg FWID Version 00000 (00256)NXC-ME260/64M (00001)AMX Corp. 00336 v3.12.335 (PID=0:OID=0) Serial=0,0,0,0,0,0,0,0,0,0,0,0, Physical Address=IP 172.16.100.10:1319 (00:60:9f:90:7a:54) (00256)vxWorks Image (00001) 00337 v3.12.335 (PID=0:OID=1) Serial=N/A (00256)BootROM (00001) 00338 v3.00.316 (PID=0:OID=2) Serial=N/A (00256)AXLink I/F uContr(00001) 00270 v1.03.14 (PID=0:OID=3) Serial=0000000000000000 >Marc is absolutely right. The 64 cannot be upgraded to duet.
I think you mean "ONLY the 64 can be upgraded to Duet" :-)
It's the NXC-ME that cannot be upgraded to Duet (I incorrectly thought I was referencing this box).
