Home Duet/Cafe Duet
sending hex to rs232 device
was trying to create a simple duet module but encounter this problem, how do i send hex from java to the device? please advice.
Thanks in advance
Alex
  • sonnysonny Posts: 208
    I'm assuming you mean you need to send binary data, as opposed to ASCII data,
    depends on how you need/want to build the packet, but I use a string buffer...
    StringBuffer packet = new StringBuffer();
    packet.append((char) 0x01);
    packet.append((char) 0x2B);
    packet.append((char) 0x0D);
    packet.append((char) 0x0A);
    // etc...then
    dv.sendString(packet.toString());
    you could also use a character array
  • alexhoalexho Posts: 7
    Hi sonny,
    thanks the above reply is of great help to me.
    thanks alot
    Alex
