ICSnet for NI-3100 retro-fittable?
in AMX Hardware
Can the "daughter card" for ICSnet be retro-fit to an NI-3100 if you need it later?
Does anybody know why this previously-standard NI-3000 feature was made optional on the NI-3100 with a price increase?
The memory was doubled and processor speed increased to offset the cost of the missing ICSNet connections. So without the ISCNet option the price of an NI-2100/3100 is the same.
It is my understanding that ICSNet is not used that much any more. From a technical standpoint, I actually like the bus for expanding a system. Despite Ethernet being a standard, a dedicated control bus like ISCNet has an advantage for transmitting data between control nodes.
Currently, the ICSNet bus is the ONLY avenue I see for adding any NetLinx
module boxes.
I personally think this was a bad decision to remove this connectivity as standard.
I have very few projects where there is not a need for control modules.
This would be great if AMX developed some ethernet modules. Then you could
ultimately make them wireless ethernet modules, which would be really cool.
I will definitely always order the NI with the option installed, whether I need it or not.
Frankie
There is in pricelist:
NXA-ICSNET FG2105-10 ICSNet Option Card for NI-2100 and NI-3100 NetLinx Controllers 200,00 USD MSRP
