During the final system test...
It is always a good idea to Enable Diagnostic Messages in Studio when final testing any program. Often you will find run time errors like 'zero index reference' to an array.
I do this when pushing each touch panel buttton during the final check out before leaving a system to the customer.
Make sure to test the Define_Start section as well. You need to be quick in enabling diagnostics after a reboot.
Also, simulate a power interuption to see how the entire system (including controlled components) will behave. I have gotten into the habit of always putting the control system into a known state upon reboot. This includes, but not limited to, powering off components, clearing A/V routing, refreshing all touch panels, and resetting program variables.
Any other good ideas?
I *always* have a telnet session running with "msg on" and once in a while during a reboot I will reconnect as quickly as posible so I can watch what happens on startup. This way you very quickly pick up runtime errors and can save a lot of debugging time by fixing the runtime errors before you start fixing any behavioural errors that might be caused by them.
"What about screen real estate?" You might ask. Easy: second hand 21" CRTs cost AUD150. I have two. My desk is groaning but they light and heat the room nicely! In this day and age anyone trying to write complex coptrol systems code through a 1024x768 portal is crippling him or herself unnecessarily.
BTW a tip for repeatedly establishing a telnet session without all that typing:
Start / Run 'cmd'
Find out which directory you are in
Create a txt file in that directory called "a.bat" containing your telnet command eg "telnet 192.168.0.100"
Type a<enter> in cmd.
I do the same; I feel handicapped when I don't have my second monitor connected. What I really would like though, is a rig like this: http://www.matrox.com/graphics/en/gxm/products/th2go/gaming/home.php .
Believe it or not, in a large home system my son can really find programming bugs. I would never think of push some of the combination of buttons that he does. He isn't that bad at programming either, they learn fast!
Of course the Monkey pushed a sequence of buttons that locked up the system. I got a call the next morning to come down and re-boot the system and get it back online. I had to go back to the video to see what the Monkey pushed to lock the system up.
As it ends up the Monkey pushed a couple of buttons that I would have never assumed anybody would ever press in that order.
Teaches me to assume...
Most problems i come across have something to do with a lost wifi link (try to solve that) or locking up equipment. Problem with those errors, is that you aren't going to find them when testing, because your test environment is almost always flawless.
Pressing a random number of keys will certainly get the most errors out, but you can't find them all until you get to the jobsite and do your final system check
I find myself repeating this like a mantra: "This is a custom installation. We have done everything we can to insure it is working properly, but the fact that it is completely unique means that there may be a minor bug we haven't noticed, but will only show up after being used on a day-to-day basis. We remain committed to ironing all these bugs out, so don't hesitate to report them when you think you have found one."
Often, customer-found "bugs" are really just things not working as they expected, though they work entirely as I intended. I'll explain my reasoning, and let them decide if they want it changed or not. This kind of flexibility doesn't come cheap though, and you have to build it into your pricing.
This is such a great point.
Every writer needs an editor just like every NetLinx programmer needs a button pusher. I believe this should be the person assigned to train the end user on system operation and functionality. Sometimes this is the salesperson, but I prefer the project engineer or project manager.
What bothers me is when the button pusher verbalizes what needs revising instead of providing a written list.
All monkeys aside:
I have to agree completely - I find myself pushing the same buttons again and again, because I wrote the code and know how the system is supposed to work, according to me. That is not necessarily the way the customer wants it to work. I always want somebody else to push button on systems just to watch how they would go through the system, and how that differs from teh way I would go through the system.
As a sub-contractor though I am finding it harder to find anybody to do that. There seems to be a growing trend that the programmer is the last one on the site - so they have to test the system. Often times I find myself spending more time pointing out video wiring problems than I do getting input on the touchpanels.
Some people communicate well in writing; some don't. The latter evolve to become software users. No idea why.
