Front button setup access code
in AMX Hardware
Hi,
is it possible to have a passcode to enable users to get into setup mode using the front button? I've tried to set a password in the panel, which didnt work.
Offcourse i can make a button on the TP with a code attached to it, but the customer wants to use the big button on the front
It's a CV7, so im talking about the big button (light sensor) in the middle of the panel
nope, and when you use the "show external buttons" in TP4, you can program the external buttons, but not the light sensor button...
