Button Interaction
I am using an AMX VPT-CP.
We use it to route different sources IE Cable box 1, Cable Box 2, DVD Player to different
televsions.
Lets say for example I have two sources
Cable box 1
Cable box 2
and two televisions
Tv 1
Tv 2
I would have 2 different pages one to select the source and one to select the destination
The question is would there be any way that I can show on the destination page on the specific buttons what source is currently routed to that particular destination that would automaticely change if the source where changed on the remote.
Would there be a way that I could program this using the macros on the buttons. I am not positive if we have all the stuff necessary for programming from a pc, but any help would be greatly appreciated.
televsions.
Cable box 1
Cable box 2
and two televisions
Tv 1
Tv 2
then there is no way to do such a thing, you can't send info to the panel
You could do it brute force with page flips, but you'll need more than two pages.
First page: select a source and flip to a different page depending on the source. The page could indicate what source was selected.
Next page: Two buttons which flip to two different pages depending on which destination is selected. These pages would show the source destination routing required to get there.
So, you need at least seven pages. 1 page to select the source, two pages (one for each source) to select the destination and four "ultimate" pages showing each of the four possible routings.
You can get more complicated.
Lay out your touchpanel with a source area and a destination area and the rest full of buttons in some manner to choose both. Create 17 source popups (that make clear which source it is) to occupy the relevant area and group grouped for mutual exclusivity; and the same for the destinations. Add pageflips to control them. Now you can at least name the source and destination.
