Changing Popup Left, Top Properties
I keep running into this problem - so maybe someone else has too
I have a group of popups for controlling different devices like DVD, VCR, Cable TV, etc. If my user has a room with one projector - I want all the control popups to show in the middle of the page. If my user has two projectors - I want all the popups to show lower at the bottom of the page with a "Select Projector Destination" popup at the top.
I keep having to create 2 sets of popups for each device (DVD, VCR, Cable TV, etc). One set aligned in the middle of the page - another set aligned at the bottom. This is incredibly annoying as it doubles the number of pages I have and the only thing that is different is the Top and Left General Properties.
I'm pretty sure I can change where a page starts appearing for an effect, but this doesn't really help. Has anyone figured out a way to get around this?
it seems to remember where the popup was last left. if the popup pages are small it works well. the channel code is 0:70 and I assign it to the background part of the popup.
"'^SHO-<variable text address range>,<command value>'" Show or hide a button with a set variable text range. Syntax: SEND_COMMAND <DEV>,"'^SHO-<vt addr range>,<command value>'" Variables: variable text address range = 1 - 4000. command value = (0= hide, 1= show). Example: SEND_COMMAND Panel,"'^SHO-500.504&510.515,0'" Hides buttons with variable text address range 500-504 & 510-515.
