Dedicated Micros Digital Sprite 2
Has anyone been able to display the video feed from a digital sprite 2 on an MVP-8400 touchpanel? I was just reading the new specs and it seems they support M-JPEG video feeds, but talking with their tech support doesn't yield any useful info thus far. I am in the process of applying to be part of their SDK program, but I figured I would ask here to see if anyone has had any luck.
Has anyone found a DVR unit for security cameras that integrates well with AMX and supports M-JPEG video?
I'm looking at one of these for a current project, ATV Falcon FA-XD16 coupled with a Talon 16 multiplexer. I don't think either has a native LAN video feed, but I'm not sure of that, and I don't particularly have a problem throwing an external one on an output of the multiplexer. I've used the multiplexers before, and they are very easy to control.
Pat C
TECHTERIORS, LLC
In your case, you could:
1) Have the Axis video server connected to the video output of the Sprite2
2) Create a Dynamic Image on the MVP-8400s. Since the Axis max res is 704x480, you will still have enough space to put the DVR control buttons on the same page as the Dynamic image window. See AMX tech Note # 682.
3) The Axis Server We use is the 241S. Use the 2CIF resolution.
Ricardo
I'm looking at getting the M-JPEG video feed from a Sprite2 onto an 8400 also.
Have you had any luck with this?
thanks
This problem as well as their removal of the ability to use the event log via 232 have prompted us to explore other options for future projects. They really seem to have little regard for even maintaining their exist functionality in new version of the firmware.
I've had some interest here too...video display on Modero panels from the Dedicated Micros DVR. Haven't put my hands on one yet, but interested in anything you find out.
i was able to do this with streaming video using cgi commands
