Home AMX Resource Management Suite Software
Two question of meeting manager
hi all,
1, how to activate the meeting manager?
2, i can't set my admin password, when i load the admin web page, also can't login. why?
please give me some advice.
Thanks!
  • Starting and Setting Password in RMS
    You would need to run the RMS Configuration Wizard on the Windows Server. Under "Services" Select Register and then Start. Under "System Settings" select "Administrator" and enter username and password.
  • KimsonKimson Posts: 33
    thanks!
    i had already do that, but, i still can't login by admin right.
    and i had register the services. by the reply of amx, the meeting manager still haven't activate.
    so, could u please give me other advise?
  • RMS Server Operating System
    Could you tell me what language your server operating system is using?
    US English
  • RMS problem
    The best method to troubleshoot this problem is through AMX tech support. They have the resources to help you verify and fix most problems.
