My first AMX program :)
Hi all!
I just finished my first program :)
I get the input output leds on the NI300 to turn on when pushing some buttons on the TP (8400)
but I don't see the leds of the port ...
also when I connecting to the controller vis web browser I can see any devide on the devices list...
can someone have a look if my program is missing somthing crusial?
thanks a lot!
PROGRAM_NAME='room_1_program'
(* System Type : NetLinx *)
(* REV HISTORY: *)
(* DEVICE NUMBER DEFINITIONS GO BELOW *)
// my touch panel device
dvTP = 10001:1:0
// Denon DVD 2800 Device (controller:device:system)
dvDVD2800 = 5001:1:0
(* CONSTANT DEFINITIONS GO BELOW *)
DEFINE_CONSTANT
DVD_PLAY = 1
DVD_PAUSE = 2
DVD_NEXT = 3
DVD_PREV = 4
DVD_FAST_BACKWARD = 5
DVD_FAST_FORWARD = 6
DVD_STOP = 7
DVD_PLAY_IR = 1
DVD_PAUSE_IR = 3
DVD_NEXT_IR = 4
DVD_PREV_IR = 5
DVD_FAST_BACKWARD_IR = 6
DVD_FAST_FORWARD_IR = 7
DVD_STOP_IR = 2
(* DATA TYPE DEFINITIONS GO BELOW *)
DEFINE_TYPE
(* VARIABLE DEFINITIONS GO BELOW *)
VOLATILE INTEGER nDVDBtns []=
DVD_PLAY,
DVD_PAUSE,
DVD_NEXT,
DVD_PREV,
DVD_FAST_BACKWARD,
DVD_FAST_FORWARD,
DVD_STOP
(* LATCHING DEFINITIONS GO BELOW *)
DEFINE_LATCHING
(* MUTUALLY EXCLUSIVE DEFINITIONS GO BELOW *)
DEFINE_MUTUALLY_EXCLUSIVE
(* SUBROUTINE/FUNCTION DEFINITIONS GO BELOW *)
(* STARTUP CODE GOES BELOW *)
(* System Information Strings ******************************)
(* Use this section if there is a TP in the System! *)
SEND_COMMAND TP,"'!F',250,'1'"
SEND_COMMAND TP,"'TEXT250-',__NAME__"
SEND_COMMAND TP,"'!F',251,'1'"
SEND_COMMAND TP,"'TEXT251-',__FILE__,', ',S_DATE,', ',S_TIME"
SEND_COMMAND TP,"'!F',252,'1'"
SEND_COMMAND TP,"'TEXT252-',__VERSION__"
SEND_COMMAND TP,"'!F',253,'1'"
(* Must fill this (Master Ver) *)
SEND_COMMAND TP,'TEXT253-'
SEND_COMMAND TP,"'!F',254,'1'"
(* Must fill this (Panel File) *)
SEND_COMMAND TP,'TEXT254-'
SEND_COMMAND TP,"'!F',255,'1'"
(* Must fill this (Dealer Info) *)
SEND_COMMAND TP,'TEXT255-'
(* THE EVENTS GO BELOW *)
BUTTON_EVENT[dvTP, nDVDBtns]
STACK_VAR INTEGER nBtnIndex
nBtnIndex = GET_LAST(nDVDBtns)
SWITCH(nBtnIndex)
CASE DVD_PLAY:
PULSE [dvDVD2800, DVD_PLAY_IR]
CASE DVD_PAUSE:
PULSE [dvDVD2800, DVD_PAUSE_IR]
CASE DVD_NEXT:
PULSE [dvDVD2800, DVD_NEXT_IR]
CASE DVD_PREV:
PULSE [dvDVD2800, DVD_PREV_IR]
CASE DVD_FAST_BACKWARD:
PULSE [dvDVD2800, DVD_FAST_BACKWARD_IR]
CASE DVD_FAST_FORWARD:
PULSE [dvDVD2800, DVD_FAST_FORWARD_IR]
CASE DVD_STOP:
PULSE [dvDVD2800, DVD_STOP_IR]
} // END OF - SWITCH
} // END OF - PUSH
} // END OF - button event MainSetup
(* THE ACTUAL PROGRAM GOES BELOW *)
DEFINE_PROGRAM
(* END OF PROGRAM *)
(* DO NOT PUT ANY CODE BELOW THIS COMMENT *)
  • First and short view:
    dvTP = 10001:1:0
    your Device is a RS 232 not a IR Interface
    dvDVD2800 = 5001:9:0
    thats your first IR Interface..
    Don't forget: Load your *.IRL File to the Device 5001:9:0
  • travtrav Posts: 188
    Well...
    5001:1:0 is a serial port, not an IR port. So that probably won't be helping much.
    Try changeing your port to
    If it is a 2XXX series, ports 5-8
    or if its a 4XXX/3XXX ports 9-16 are the IR ports
    A 700's IR port is port 3 and a 900 is ports 2-4,
    Don't forget to upload an IR file to the port first !
    Good Luck :)
  • adysadys Posts: 395
    Oppsi :)
    now it working!
    thanks guys
    ady
  • vincenvincen Posts: 526
    Also don't use PULSE to send IR, it's too messy to manage when you need different times of pulse between devices controlled through IR and also doesn't manage queue in IR commands on a same port.
    Always use SEND_COMMAND with SP, or XCH (Very useful for control of cable or sat boxes), and set up each port with a SEND_COMMAND CTON and CTOF in online of each IR Port ;)
    Vinc
