Newest G4 upgrade 2.7.0
Thomas Hayes
I was able to download G4, 2.7.0, ver 545 this morning but when I tried to update my laptop this afternoon it no longer shows up. Is there a problem with this lastest download that I need to un-install it and reload the earlier version?
Why release a version of a software program that supports hardware that isnt even going to be available for another month or so...
They could have waited with it, and fix some more bugs i reckon
Or, maybe they just want to give people the chance to play with the software and keep interest piqued in the R4? (/me stops dancing like a moron)
Either way, I am excited to be able to play with the software to start to clear up my understanding of what will and won't be allowed on the R4.
P.S.
We are talking about support for the R4, right?
I'm unable to do now any transfer from TPD4, each time it blocks at same place
Vince
If you still can't fix it, get a new flash card from AMX, i think they don't charge you for it.
Thanks for the tip, but am I supposed to be able to transfer through USB on 1200VG panel ? If so in telnet to panel it offers me only Ethernet or ICSP for connection to master
Vinc
i dont think ICSP is the way to go...
On the other hand, telnet should be giving you the option to revert to a base system, or is that only on Netlinx frames?
I think you misunderstood my previous message. 1200VG panel is a G4 panel, latest generation of Moderos Panel with streaming support. Moderos with USB on top of unit is on MVP series.
New VG Moderos have USB ports on backside for keyboard and mouse but I don't know if we can download pages through them
Vinc
Unhappy not I hoped but clean disk command in telnet does absolutely nothing
Vince
Vincen,
Try using this:
AMX USB LAN
Install this application driver for TPDesign4 and NetLinx Studio for support of direct connection to Modero VG Series panels via USB.
ZIP | 1.60 MB | v. 2.01.05 | 2006-09-06
Thanks for the idea, but same thing, I'm able to see Modero on USB connection, connect to it from TPD4 but transfer blocks in same way
I tried also a reload of firmware but it blocks always when it wants to transfer VTG file so I suspect something is wrong on CF card !
Noone would have a dd copy of a CF card for VG Moderos ?
Vince
do you think that would help? Just get a new card from AMX
