Using Aprilaire 8825 (IP Control) Module
I've seen lots of discussion on the forum about using the 8811 (RS422 Control) module, but nothing about the new 8825. We recently installed one and are getting null pointer errors returned from the 8825 module, so it fails to load. Anyone have any success with the 8825 and the Duet module available on InConcert? If so, any pointers on how to get this thing to work right?
Patrick Clemins
TECHteriors
Patrick Clemins
TECHteriors
For future reference, I got the module working and the Aprilaire 8825 box configured correctly with the help of Stephen Steiner and the rest of the AMX staff. It works extremely well and provides good feedback as to the state of the HVAC system.
Curt
Trikin
I'm going to have to try asking for Stephen. I have a non-communicative module here, and the person I talked to said, and I quote, "You'll have to call April Aire about any setup questions." The problem is the people at April Aire know nothing at all besides the browser interface. They could not even tell me how to activate the so-called "passthrough" mode referenced by AMX in the module docs. And nowhere in said module docs is any reference how to set the module parameters to talk to your installation - I had to dig through the sample code to even find out how to set the IP address.
From the errors I am getting, it would seem it is trying to connect to the wrong port. Aprilaire had no idea of any port except 80 and 443 - which are, of course the web browser and not applicable.
Pat
I agree that the lack of scheduling in the module does kinda stink, but I suppose that's the purpose of iSchedule now, isn't it
Pat
i!-Schedule or/and i!-MacroManager principles for developing his Scheduler. However, most entry/mid level AMX programmers will have a hard time doing what Vining did. I thank Vining for sharing his Scheduler with us and all my future jobs will have it. Some of my clients are asking about HVAC Scheduling. What do you guys handle that?
I was able to adapt Vining's Scheduler to work with ICSNet as well, and I am also looking at the IP alternative for larger jobs. How good is the communications via IP using the homelogic brick? What happens if power fails, the link is lost or some thermostats are powered off? Does it auto sync?
Ricardo
As far as therms going on and off line... the module seems to handle this well.
Pat
Ricardo
It's no longer posted but if you'd like I can email it directly.
The one that magically appeared on a job i'm doing had what looked like a cat 5 type female plug on it labelled RS-232 that I was hoping to be able to use so that we could have the web interface and control from AMX at the same time.
Were you able to use the Rs-232 on the 8825 from the AMX?
You can't use the 8825 for RS-232, but there is another control adapter to use for that... the 8811.
Pat
If it does I was thinking that if you had two ports available perhaps you could hook one to the 8825 and one to the distribution panel and forward messages between the two ports and interject commands from the Netlinx system as needed.
Tried that, it still doesn't work. The 8825 simply takes over mastering the buss, and nothing else can act as a master as long as it is there.
It's out of my hands at the moment for existing jobs; I'll try to pitch him on your interface the next one ... assuming he doesn't decide to switch thermostats entirely. We have had a history of quality control issues with Aprilaire.
DHawthorne wrote: You didn't smack sense into him? He must have already paid for the 8825 brick.
