Touch panel video over LAN
Hello.
Does anyone know if there is a way to see the video on the touch panel from a remote computer?
I can get to the touch panel and control it but the video is blacked out when logged from the network. Is this normal? The video works fine on the touch panel locally.
THANKS
THANKS
None that I know of. I don't think the VNC connection would be able to refresh quick enough to keep up with the video.
Yes a have composite video to the panels via the breakout box.
So if I use a axis video server to send video to the panels, than I can remotely access into the panels and see the video? but not if I have a hardware video sent to the panels?
THANKS
Is there a way to resize this video window coming from the axis server or are you limited by the axis server output resolution? Like when you have a video window and you tap on it, to get a full screen image.
Never mind. I think I found my answer here:
http://www.amxforums.com/showthread.php?t=1092&highlight=video+window
