Extron IP Link
Hi,
I am interested in using some extron iplink rs232 controllers, I see there is a module that can be used with RMS but is it possible to connect to these controllers without using RMS?
Hi all,
Wanna seek your advise in controlling Extron Crosspoint Switcher via IP Link. Is there any module which I can use or can anyone give me some advise on doing this?
DATA_EVENT[dvSWITCH] { OFFLINE: { IP_CLIENT_CLOSE (dvSWITCH.PORT) WAIT 5 { IP_CLIENT_OPEN(dvSWITCH.PORT,'xxx.xxx.xxx.xxx',23,1) } } }There should also be an ONLINE: section and if needed, an ONERROR: section. Depending on how you need the event handled, your ONLINE and ONERROR will be different than mine. I am a noob compared to most of you guys, so my way might not be the best way, but it works. I noticed with Extron switches, for some reason, they seem to drop comms after sitting there with no communications. That caused a problem when the user would then try to make a change on the switch. This OFFLINE portion is hanging up and then calling the switch again. I haven't had any problems anymore.
Concerning modules, I have never used one. I prefer to bang my code out the long way. With what most of my users are doing, I think it is just easier to program it as compared to modifying the module to meet their needs. Most of the time the modules have more stuff in them than what my users are trying to accomplish.
