falling down auto type cast float to integer
Odd thing...
an_Int = a_Float*255.0
an_Int = 255.0
Compiler says:
ERROR: File.axs(1): C10512: Cannot convert type [FLOAT] to [INTEGER]
ERROR: File.axs(2): C10533: Illegal assignment statement
WARNING: File.axs(2): C10571: Converting type [FLOAT] to [INTEGER]
So my question is: Why does it fail on the first conversion not the second? and how do I fix it?
  • Odd thing...
    an_Int = 255.0
    Compiler says:
    So my question is: Why? and how do I fix it?
    The compiler will not test if the result of the operation is a full number (i.e. 255.0). The compiler just sees in both operations a pass of a Float value into an Integer, which is not allowed.
    A TYPE_CAST() will "cut off" the values after the comma
    an_Int = TYPE_CAST(a_Float*255.0)
    an_Int = TYPE_CAST(255.0) // an_Int now is 255
  • Thanks alot.
