WebControl Not Working after IE7 Upgrade
Has anyone else experienced the WebControl Panels not working after an upgrade to IE7? When the actual window pops up for a panel you get a red X and the following error:
Line: 72
Char: 4
Error: Object doesn't support this property or method
Also, Firefox does not work either. I have tried both with the latest Applet runtime (v.6.1) and with a downgraded 1.4.2 runtime (as I read that might help).
Thanks for any insight.
Line: 72
Char: 4
--John
http://www.amx.com/techsupport/techNote.asp?id=804
Edit: Actually it was related to a problem with a Microsoft security update (Microsoft KB916281). Still, hope this helps you out.
--John
Also, despite using a java applet (for multiplatform support I assume) will this ever support Firefox or Opera as well as IE?
Thanks Again.
