Sony EVI D100
Trying to program a Sony EVI D100, to power the unit on and off. I am not sure if I am reading the RS-232 commands right. anyone let me know if that is right. The QQ would be the command string. The 8X.... is the ON string.
send_string dvCam,"'QQ',13"
wait 10 send_string dvCam,"'8x01040002FF',13"
SEND_STRING 0, "'8x01040002FF',13"
here some sample code that may help you: Notice the stop move command takes place in the RELEASE:{}
PROGRAM_NAME='SONY EVI 100'
(* Button Event Name: VC_CAM3_BTNS *)
(* Purpose: Controls camera through AMX module *)
BUTTON_EVENT[VC_CAM3_BTNS]
LOCAL_VAR INTEGER CAM3_CURRENT_PRESET
LOCAL_VAR INTEGER CAM3_BUTTON
CAM3_BUTTON = BUTTON.INPUT.CHANNEL
IF (CAM3_BUTTON > 40)
CAM3_CURRENT_PRESET = CAM3_BUTTON - 40
SWITCH(CAM3_BUTTON)
CASE 31: (*TILT UP*)
//SEND_STRING dvSONYCAM,SONYCAM_UP
SEND_STRING dvSONYCAM,"$81,$01,$06,$01,$07,$07,$03,$01,$FF"
CASE 32: (*TILT DOWN*)
//SEND_STRING dvSONYCAM,SONYCAM_DOWN
SEND_STRING dvSONYCAM,"$81,$01,$06,$01,$07,$07,$03,$02,$FF"
CASE 33: (*PAN RIGHT*)
//SEND_STRING dvSONYCAM,SONYCAM_RIGHT
SEND_STRING dvSONYCAM,"$81,$01,$06,$01,$10,$10,$02,$03,$FF"
CASE 34: (*PAN LEFT*)
//SEND_STRING dvSONYCAM,SONYCAM_LEFT
SEND_STRING dvSONYCAM,"$81,$01,$06,$01,$10,$10,$01,$03,$FF"
CASE 35: (*FOCUS IN*)
//SEND_STRING dvSONYCAM,SONYCAM_NEAR
SEND_STRING dvSONYCAM,"$81,$01,$04,$08,$03,$FF"
CASE 36: (*FOCUS OUT*)
//SEND_STRING dvSONYCAM,SONYCAM_FAR
SEND_STRING dvSONYCAM,"$81,$01,$04,$08,$02,$FF"
CASE 37: (*ZOOM IN*)
//SEND_STRING dvSONYCAM,SONYCAM_TELE
SEND_STRING dvSONYCAM,"$81,$01,$04,$07,$02,$FF"
CASE 38: (*ZOOM OUT*)
//SEND_STRING dvSONYCAM,SONYCAM_WIDE
SEND_STRING dvSONYCAM,"$81,$01,$04,$07,$03,$FF"
CASE 40: (*SAVE PRESET*)
SEND_STRING dvSONYCAM,"$81,$01,$04,$3F,$01,(CAM3_CURRENT_PRESET-1),$FF"
SEND_STRING 0,"$81,$01,$04,$3F,$01,CAM3_CURRENT_PRESET,$FF"
IF((CAM3_BUTTON >= 41) AND (CAM3_BUTTON <= 44)) (*RECALL PRESET*)
SEND_STRING dvSONYCAM,"$81,$01,$04,$3F,$02,(CAM3_CURRENT_PRESET-1),$FF"
SEND_STRING 0,"$81,$01,$04,$3F,$02,CAM3_CURRENT_PRESET,$FF" SEND_STRING 0,"10,13"
RELEASE:
LOCAL_VAR INTEGER BUTTON_RELEASE
BUTTON_RELEASE = BUTTON.INPUT.CHANNEL
SELECT
ACTIVE((BUTTON_RELEASE = 35)OR(BUTTON_RELEASE = 36)):
SEND_STRING dvSONYCAM, "$81,$01,$04,$08,$00,$FF"
ACTIVE((BUTTON_RELEASE = 37)OR(BUTTON_RELEASE = 38)):
SEND_STRING dvSONYCAM, "$81,$01,$04,$07,$00,$FF"
ACTIVE((BUTTON_RELEASE >= 31)AND(BUTTON_RELEASE <= 34)):
SEND_STRING dvSONYCAM, "$81,$01,$06,$01,$18,$18,$03,$03,$FF"
VOLATILE CAM_ON[] ={$81,$01,$04,$00,$02,$FF}
VOLATILE CAM_OFF[] ={$81,$01,$04,$00,$03,$FF}
Cam_on = "$81,$01,$04,$00,$02,$ff"
Cam_off = "$81,$01,$04,$00,$03,$ff"
Cam_zoom_tele = "$81,$01,$04,$07,$02,$ff"
Cam_zoom_wide = "$81,$01,$04,$07,$03,$ff"
Cam_zoom_stop = "$81,$01,$04,$07,$00,$ff"
Cam_focus_far = "$81,$01,$04,$08,$03,$ff"
Cam_focus_near = "$81,$01,$04,$08,$02,$ff"
Cam_focus_stop = "$81,$01,$04,$08,$00,$ff"
Cam_up = "$81,$01,$06,$01,$07,$07,$03,$01,$ff"
Cam_down = "$81,$01,$06,$01,$07,$07,$03,$02,$ff"
Cam_left = "$81,$01,$06,$01,$07,$07,$01,$03,$ff"
Cam_right = "$81,$01,$06,$01,$07,$07,$02,$03,$ff"
Cam_drive_stop = "$81,$01,$06,$01,$03,$03,$03,$03,$ff"
Cam_home = "$81,$01,$06,$04,$ff"
Hey Thank you very much as soon as I saw that I was able to fix some mistakes.
