Mio Classsic Question
BUTTON_EVENT[dvKeypads,nKeypad_Buttons]
Steps
1. Check the power state
Is the Power off or on?
a. Power is off
i. Turn on system; switch to correct source
b. Power is on
Was the source that was just selected the same source or a different one?
i. Same Source
a. Do source function; change preset, track, etc
ii. Different source
a. Switch to correct input
nPanel_Index = GET_LAST(dvKeypads) + 5
nPanel_Address = nPanel_Index + 144
nButton = GET_LAST(nKeypad_Buttons)
//nPush = nPush + 1
debug("'MIO Keypad : ',ITOA(nPanel_Address),' - What is the current power state?'")
SELECT
ACTIVE(strWhPwr[nPanel_Index] = 'F' AND nButton < 5):
debug("'MIO Keypad : ',ITOA(nPanel_Address),' - The power is off!'")
debug("'MIO Keypad : ',ITOA(nPanel_Address),' - Turning the power on!'")
debug("'MIO Keypad : ',ITOA(nPanel_Address),' - Which zone?'")
ON[nPanel_Address,nButton] /// Feedback for button #'s 1 - 4
strWhPwr[nPanel_Index] = 'N' /// Set room power state to on
ACTIVE(strWhPwr[nPanel_Index] = 'N' AND nButton < 5):
debug("'MIO Keypad : ',ITOA(nPanel_Address),' - The power is already on!'")
debug("'MIO Keypad : ',ITOA(nPanel_Address),' - What source was selected?'")
IF(nPush > 1)
nPush = 0
debug("'MIO Keypad : ',ITOA(nPanel_Address),' - Same source pushed!'")
ELSE
debug("'MIO Keypad : ',ITOA(nPanel_Address),' - Differenet source pushed!'")
PULSE[nPanel_Address,nButton] /// Feedback for button #'s 1 - 4
WAIT 5
ACTIVE(nButton = 5):
debug("'MIO Keypad : ',ITOA(nPanel_Address),' - Power off selected!'")
debug("'MIO Keypad : ',ITOA(nPanel_Address),' - Which Zone?'")
ON[nPanel_Address,nButton] /// Feedback for button # 5
strWhPwr[nPanel_Index] = 'F' /// Set room power state to off
I am trying to program for the MIO Source buttons. I need it to do the following:
1. Check the power state [done]
Is the Power off or on? [done]
a. Power is off [done]
i. Turn on system; switch to correct source[done]
b. Power is on [done]
Was the source that was just selected the same source or a different one? [done]
i. Same Source
ii. Different source [done]
With the above code I am having I need it to do the source function until the source is change to another source. What I am running into to is, that it works fine for the 1st & 2nd push, but after the second push it resets nPush = 0 and starts over.
I guess my question is how do you setup the code to do the source function ( next track, preset, etc ) until the source is changed?
Thanks for the help
Chris Ondrovic
If anyone else wants to know how i did it here is the code
BUTTON_EVENT[dvKeypads,nKeypad_Buttons] { /* Steps 1. Check the power state Is the Power off or on? a. Power is off i. Turn on system; switch to correct source b. Power is on Was the source that was just selected the same source or a different one? i. Same Source a. Do source function; change preset, track, etc ii. Different source a. Switch to correct input */ PUSH: { nPanel_Index = GET_LAST(dvKeypads) + 5 nPanel_Address = nPanel_Index + 144 nButton = GET_LAST(nKeypad_Buttons) debug("'MIO Keypad : ',ITOA(nPanel_Address),' - What is the current power state?'") SELECT { ACTIVE(strWhPwr[nPanel_Index] = 'F' AND nButton < 5): { debug("'MIO Keypad : ',ITOA(nPanel_Address),' - The power is off!'") debug("'MIO Keypad : ',ITOA(nPanel_Address),' - Turning the power on!'") debug("'MIO Keypad : ',ITOA(nPanel_Address),' - Which zone?'") ON[nPanel_Address,nButton] /// Feedback for button #'s 1 - 4 strWhPwr[nPanel_Index] = 'N' /// Set room power state to on } ACTIVE(strWhPwr[nPanel_Index] = 'N' AND nButton < 5): { debug("'MIO Keypad : ',ITOA(nPanel_Address),' - The power is already on!'") debug("'MIO Keypad : ',ITOA(nPanel_Address),' - What source was selected?'") IF(nCur_Source = nButton) { debug("'MIO Keypad : ',ITOA(nPanel_Address),' - Same source pushed!'") debug("'MIO Keypad : ',ITOA(nPanel_Address),' - Which zone?'") } ELSE { nCur_Source = nButton debug("'MIO Keypad : ',ITOA(nPanel_Address),' - Differenet source pushed!'") debug("'MIO Keypad : ',ITOA(nPanel_Address),' - Which zone?'") } PULSE[nPanel_Address,nButton] /// Feedback for button #'s 1 - 4 WAIT 5 { ON[nPanel_Address,nButton] /// Feedback for button #'s 1 - 4 } } ACTIVE(nButton = 5): { debug("'MIO Keypad : ',ITOA(nPanel_Address),' - Power off selected!'") debug("'MIO Keypad : ',ITOA(nPanel_Address),' - Which Zone?'") ON[nPanel_Address,nButton] /// Feedback for button # 5 strWhPwr[nPanel_Index] = 'F' /// Set room power state to off } } } RELEASE: { nCur_Source = nButton } }
