PC1 and PC2 with 220v?
in AMX Hardware
I know the PC1 and PC2 are 110v US only, but has anyone tried using them with 220v like in Europe? Any hints for similar devices to use with 220v?
Bob
Bob
Because Eurpean 220volts is basically the same as US 120volts a PCS would probably work as it really does nothing to the AC passing through it other that an inductive reactance through a current sensing coil. You would need need a European plug adapter kit and you should check the device listing to see if this is permitted. US 240 volts you could do something similar to just one leg (both legs draw equal current) but why play around with adapting power cords and the like when there are plenty of current sensing equipment available out there. Some you just wrap the cord or a single hot leg around an induction coil. Do a google for current sensors or current sensing relays and you should find tons of stuff. Then you can go straight to an IO or to the IO via another relay.
@NMarkRobers: Thanks much for the hint. The local distributor has basically 220v switching gear which is placed on rails in the electrical distribution panel which is not the same as the PC2 box making a nice fit near AV gear in the rack. I will try and check the australian AMX page.
