Firmware update
I am tring to update firmware of NI3000 - to v3.21.343 (currnely I have v3.11.323)
I am getting the message :
Transfer aborted - not enough memory on device to hold file
Memory required : 526901 Memroy availble :458752
Why is this?
thanks
Ady
P.s
The resone is that I am having bad ip connections between the TP and the controller without any reason.. I thought maybe firmware update will help.
Any other ideas will be welcome
Why is this?
thanks
Ady
P.s
how to do it?
I didn't have problems with the NI3100... I guess he got more memory
Adys, The Firmware File you have is for the Master Processor.. in specific Term for Device 0:1:0... so make sure not typing 5001 in the device ID field
i had this problem before, i wasn't an AMX Dealer yet and i didn't have the access to the files on the web so they sent me the wrong file
Cheers
Are you using the correct firmware file? There are different files for the NI-x000 and NIx100 series.
And it's works!
