Algolith Dragonfly
Hi all
I am using this scaler
http://www.algolith.com/index.php?id=dragonfly&L=0
all I have to do it to control it with simple serial commands but it stucking all the time..
anyone worked with this scaler?
and how can I use this IR codes from AMX? (his remote can't be learn too...)
http://www.algolith.com/fileadmin/HomeTheater/Dragonfly/3011-8006MM-100.pdf
What can I do with those codes?
Ady
Ady
As far as the IR, use AMX IREdit to convert pronto hex codes to a complete AMX IR File.
the protocol is very simple, its not a protocol issue..
http://www.algolith.com/fileadmin/HomeTheater/Dragonfly/3011-6004DS-002_Remote_Control_Protocol_Design_Specification.pdf
even when we are working with the IR remote that come with it there are probelms when we connect HDMI input. when we are working with Svido inputs every thing is ok...
But just wanted to know how to work with IR codes.
The ir edit discreet code don't take them... the format is not good for AMX
Command Power Toggle
IR Code 12
HEX Code 0x0000000C
Pronto TSU-3000 IR Code 5000 0000 0000 0001 0018 000C
is there any way to convert pronto hex codes to AMX ir file?
0000 006D 0024 0000 0155 00AB 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0040 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0040 0016 0016 0016 0040 0016 0040 0016 0016 0016 0040 0016 0016 0016 0016 0016 0040 0016 0016 0016 0016 0016 0016 0016 0040 0016 0016 0016 0040 0016 0040 0016 0016 0016 0040 0016 0E55 0155 0055 0016 00AB
This remote cannot be learned, so how can I use IR control if the codes are not good for AMX?
We tried to learn the remote with RTI, not with Iris.
I don't have pronto...
I will try your file next time I will be at the customer home
Thanks a lot for the effort,
Ady.
Is this an actual dragonfly command? If so where did you find it? I can not find any codes (long or short) on the remoteCentral.com website. I was able to capture all of the remote commands on the IRIS using special mode, but there are a number of IR functions listed on the algolith website that do not have corresponding button pushes on the physical remote.
