VPT-CP firmware v5.01m and TPDesign3
in AMX Hardware
Is this firmware compatible with TPDesign3? I can't seem to get a serial connection to work.
Thanks; you were right
I made my own cable from http://www.amxforums.com/showthread.php?t=2126&highlight=vpt-cp
However, the following is for a straight through cable, not for use with a crossover:
2 - tip
3 - ring
5 - sleeve.
If you use this configuration, you don't need a crossover cable.
I hope this helps anyone in the future who has to make their own cable. Parts from Radio Shack listed below
Catalog #: 276-1539 9- and 15-Position D-Sub Connector Hood
Catalog #: 274-244 RadioShack Gold Series 3/32" Stereo Plug
Catalog #: 276-1537 9-Position HD Male Solder D-Sub Connector
