Home AMX Control Products
Colour picker code.
The internal colour picker on the touchpanels is not transmited to the master.
So I wrote code to take three floats in the range 0.0 to 1.0 as a hsl colour, and create rgb colour in hex to send to buttons and use to drive lighting control from the DMX512 box.
Heres my code and the main function for those who had similar requirements.
DEFINE_FUNCTION HSLtoRGBHex(FLOAT HSL[], CHAR hexrgb[])
    FLOAT temp1, temp2, t3[3], clr[3]
    INTEGER index
    INTEGER red, green, blue
     IF(HSL[3]=0.0)
	clr[1]=0.0
	clr[2]=0.0
	clr[3]=0.0
     ELSE
	IF(HSL[2]=0.0)
	   clr[1]=HSL[3]
	   clr[2]=HSL[3]
	   clr[3]=HSL[3]
	ELSE
	    IF(HSL[3]<=0.5)
		temp2 = HSL[3]*(1.0+HSL[2])
	    ELSE
		temp2 = HSL[3]+HSL[2]-(HSL[3]*HSL[2])
	    temp1 = (2.0*HSL[3])-temp2
	   t3[1] = HSL[1] + 0.3333
	   IF(t3[1] < 0.0) t3[1] = t3[1] + 1.0
	   IF(t3[1] > 1.0) t3[1] = t3[1] - 1.0
	   t3[2] = HSL[1]
	   t3[3] = HSL[1] - 0.3333
	   IF(t3[3] < 0.0) t3[3] = t3[3] + 1.0
	   IF(t3[3] > 1.0) t3[3] = t3[3] - 1.0
 	   FOR(index=1;index<4;index++)
		IF((6.0*t3[index]) < 1.0)
		    clr[index]=temp1+((temp2-temp1)*t3[index]*6.0)
		ELSE
		    IF((2.0*t3[index]) < 1.0)
			clr[index]=temp2
		    ELSE
			IF((3.0*t3[index]) < 2.0)
			    clr[index]=(temp1+((temp2-temp1)*(0.6667 - t3[index])*6.0))
			ELSE
			    clr[index]=temp1
    red   = TYPE_CAST(clr[1]*255.0)
    green = TYPE_CAST(clr[2]*255.0)
    blue  = TYPE_CAST(clr[3]*255.0)
    hexrgb = "FORMAT('%02X', red),FORMAT('%02X', green),FORMAT('%02X', blue)"
LEVEL_EVENT[TP,1] // Hue 0 - 255
LEVEL_EVENT[TP,2] // Sat 0 - 255
LEVEL_EVENT[TP,3] // Lum 0 - 255
    CHAR RGBH[6]
    // store hsl colour in global
    TPHSLColour[level.input.level] = level.value/255.0
    // convert to RGBHex
    HSLtoRGBHex(TPHSLColour, RGBH);
    // make command to set button 1 to the picked colour
    SEND_COMMAND TP, "'^BCF-1,0,#',RGBH"
  • yuriyuri Posts: 861
        INTEGER index
         IF(HSL[3]=0.0)
    	clr[1]=0.0
    	clr[2]=0.0
    	clr[3]=0.0
         ELSE
    	IF(HSL[2]=0.0)
    	   clr[1]=HSL[3]
    	   clr[2]=HSL[3]
    	   clr[3]=HSL[3]
    	ELSE
    	    IF(HSL[3]<=0.5)
    	    ELSE
    	   t3[2] = HSL[1]
    		ELSE
    			clr[index]=temp2
    		    ELSE
    			ELSE
    			    clr[index]=temp1
        CHAR RGBH[6]
    the colour picker code is transmitted to the master :p
    check this out
    http://amxforums.com/showthread.php?t=2594
  • ok!
    I can see trav's code that requires a button press to get the colour.
    And your reply about your code but I don't see your code!?
  • travtrav Posts: 188
    He's just slack :) or he forgot to attach the code :P
    both :p
    here it is :)
    Ah HA! You took the hack one step further and did the copying to a button inside the hold event.... sneaky.
    Cheers for that :)
    Cheers for that :)
    check out the little dot on the left bottom corner of the colour picker. That's actually the button i'm copying to ;)
