Web Console Too Slow
John Gonzales
in AMX Hardware
How fast should I be able to communicate with a master using Web Console. I'm not talking baud rates, but it takes several seconds to several minutes for pages to load sometimes even on a local network connection. Are there some suggestions to speeding up the communication with Web Console on the NI-x100 masters?
Thanks.
--John
Thanks.
--John
--John
OK that's never given me any trouble.
I wonder if this is part of the same thing that makes the G3Panels so slow . . .
J
Jeremy
I'll give the firmware update a try and see if it helps. I'll post some results a little later today.
--John
--John
the panels load instantly with vnc.
I was having this problem, even after installing 354 firmware, but doing a clean disk and setting duet memory to 5MB will do the job.
