Home AMX Design Tools
Address and Channel???
Can somebody give me a quick overview of the differences between Addresses and Channels and how they relate to feedback to and from a master? The help documentation in TPD4 seems woefully inadequate for newbies and doesn't give a good explanation. I'd settle for a URL to some good documentation on the subject if you know of any.
Thanks for the help,
Derek.
    A probably over simplified answer is that Channels are what are used to denote which button got pushed, released (and by inferrence, held)
    BUTTON_EVENT[tp_1,1]
      // some one pushed button 1, do someting.
      someone_did_something=1
    Channels are also used for feedback.
    DEFINE_PROGRAM
    IF(someone_did_something=1)
      ON[dv_tp,1] // TURN ON THE FEEDBACK OF BUTTON 1
      someone_did_something=0 // reset the var
    NOTE: turning a touch panel button channel on does not equal pushing it.
    The Address portion is typcially used for variable text.
    So,
      SEND_COMMAND dv_tp,'TEXT1-HEY! Stop pushing this button!"
    Note: The Address number doesn't have to be the same as the channel number. It could be button Channel 1 and Address 101. If that were the case the above example would look like..
      SEND_COMMAND dv_tp,'TEXT101-HEY! Stop pushing this button!"
    Sorry to use old programming methods, but sometimes it's the easiest way to explain it...
