No Feedback From Lutron
There was a 29 hour power outage inp the Westchester, Ny area last week. All Lutron keypads are working fine switching on the correct switches and graphic eyes with feedback on the Lutron keypads. All AMX panels are switching off and on the correct lights and switches.
PROBLEM: There is NO FEEDBACK ON THE AMX PANELS.
Have rebooted the Lutron, the AMX etc.
Any help??
Any help??
2nd the serial device driver for the port connected to AMX probably wasn't set up properly for the desired feedback needed so when the HomeWorks processor was affectively power cycled it rebooted back to default. Possibly with your generator it hasn't been an issue before.
If your data_event has code similar to that shown above you can just reboot the AMX and your feedback should return.
Homeworks or Interactive? If its an Interactive processor and the baud rate on the rs-233 port is something other than default, cycling the power on the Lutron processor will reset it to its default unless there is a "driver" programmed to that communication port. Default is hardware flow control (CTS and RTS enabled) at 38.4k (I think)
Is it possible that the power storm did something that requires the program to be downloaded to my Netlinx processor in order to regain feedback to the AMX panel??
Still waiting on the programmer to get back from vacation. This is going to be interesting
sense as to what is happening. It appears as though the data coming
back is correct but not showing the right info for the LED keypad
status... (level status is fine changed a global parsing character to
match what has changed from Lutron
