ZigBee Wireless Range
I just ran a simple test that toggles a button on and then off every second while holding down the vol up button on a R4 remote and did this while walking about. I must say the range is much better that expected. Using only 1 ZigBee gateway located at the rear of my home office on the 2nd floor I was able to maintain button toggling in the most front lower level rooms about 70' away through hardwood floors and walls. Walking about the property had similar good results, across the street and even on the otherside of the neighbors house which is aluminum siding worked as well.
Very pleased!
Very pleased!
GSLogic wrote: Yeah it's pretty darn good! For a second I thought I was going to be able to walk 1/2 way down the street like you can with the Lutron car visor control.
