TouchPanel failed on update
I got a MVP-8400 touchpanel. When I update the firmware. The NetLiux program said insufficient memory while I was transferring the third file. Afterwards I rebooted the touchpanel. But I can't boot back to the logo screen.
How can I fix the problem?
    try pushing in the middle of the touchscreen while booting. this way you should get into the setup.
    winstonmawinstonma Posts: 45
    They dun even show the 'AMX' word while booting. But I will try going into the setup mode today thanks.
    If the panel stucks on the AMX Bootlogo, the firmware update has failed critical. I think a new CompactFlash card from AMX is required :(
    you dont get into the setup when pushing and holding for a minute or two while booting?
