Zone is offline
in MAX by AMX
Sometimes when I am tring to play some songs I get the message "zone is offline"
when playing it from the winmax its ok.
Any idea?
Any idea?
--John
I've noticed that we tend to have the problem after the client tries to burn a disc to the server and the title isn't recognized. After that the system tends to hang and zone 1 goes offline. I believe the AMX/AMG database issues may have been resolved because we're seeing significantly fewer cases where the title isn't recognized (even with brand new titles). As a result we're seeing the zone offline message less often too. Could be coincidence, but I think it was related to the discs not being identified properly. I'm going to give the DO_PUSH solution a try too. Thanks for the info Dave!
Thanks for bringing that up Ady. Hopefully we'll all be able to get our MAX modules working flawlessly
--John
I will add a do_push too to solve this problem.
now I have 2 zones that are offline but can't be played from the WinMax too.
What is this?
I had to restart the AVM, play it from winmax, and only after that I can play it from gui...
When I am doing a master update and then reboot, zone becoming offline...
Restarting the TP - solving it.
This is very bad. its mean that every time that the power will go down on a master the zone will go offline (we don't have ups on every master)
I don't undestand why - maybe its asking about a channel in the tp for status?
What is the button that needs to be pushed?
"output" button?
