help with conditional statement
flcusat
I'm a newbie and I new some help to understand how to parse info from the device and use that info in a conditional stament. I'm working on a project right now where I need to now the input status of the display and change it to either the Tuner A for cable and the cameras modulated from channel 102 to 122 and Input 1 which is the component input. This is what I got and I would like to know if I'm in the right direction.
With the help of Danny which is a member of this forum that had help me to learn a lot I got this data event to get a variable(nTVInput) to track the input state of the TV.
Then, If I were to use the value of nTVInput and nTVPower to track the status of the TV when I want to go to the camera in Channel 104 of the TV; I would have a Button Event to do something like this.
Am I in the right track here?
DATA_EVENT[vdvTV] { STRING: { STACK_VAR char sName[32] // a temporary variable that only exists for the life of the data_event sName = REMOVE_STRING (DATA.TEXT,'=',1) // assumes the command comes back as command=value, pulls off the command= and just leaves // the value in DATA.TEXT SWITCH (sName) { CASE 'ASPECT=' : { nTVAspect = ATOI(DATA.TEXT) } CASE 'INPUT=' : { nTVInput = ATOI(DATA.TEXT) } CASE 'POWER=' : { nTVPower = ATOI(DATA.TEXT) } } }
if (nTVPower) // Power On { If (nTVInput = " 'Input-InpA,1' " ) // go to Tuner A { send_command vdvTV," 'XCH-104' " // Gate camera else { send_command vdvTV, 'INPUT-INPA,1' // TV to Tuner A wait 40 { send_command vdvTV," 'XCH-104' " // Send TV to Channel 104 } } } else { pulse[vdvTV,27] //Turn TV On. Of course I could have done another If statement after I Power Up the TV to find out in which input is at wait 50 { send_command vdvTV, 'INPUT-INPA,1' //go to Tuner A wait 40 { send_command vdvTV,"'XCH-104'" //Gate Camera } } }
My instinct would be to copy data.text into a local variable before manipulating it like that. data.text is voodoo and best not messed with.
You can't be absolutely sure that you have the whole input string, or only one input string, so it's best to buffer data.text and search for string terminators:
The TV handling code appears to mix application-layer (what do I want the user to experience) with device-driver (how do I turn on the TV). It would be normal practice to separate those two chunks of code in different modules.
Your "wait 40" looks fairly arbitrary - it's better to wait for the ACK that all serial-controlled devices give, and then send the next command.
I wonder why your output command is upper case and the reply is not.
The tracking of TV state is a good approach but the industrial-strength way is to do it like this:
Call ReviewTVState only when there is nothing in the command queue and you've received the ACK from the last command.
The advantage of this approach is that you can change requested state anywhere in your code without having to think about timing. So for instance, if the user selects a source then changes his mind and switches off, the issued command sequence will be
power on - power off
instead of
power on - input select - power off
or worse
power on - input select - what was I supposed to do next?
This is particularly important for things that take a long time to power up or need to be told a lot of stuff to do.
In dealing with DATA.TEXT, you should be careful not to throw away information you'll need later. But I think it's fine to use DATA.TEXT, in fact I usually do SWITCH(REMOVE_STRING(DATA.TEXT,'=',1)){ case 'POWER=': //etc } without an intermediary variable.
Dealing with direct output from devices is a different animal. You have no idea what you're getting in each handful. It's like putting your hand into a cookie jar (serial port), as opposed to putting your hand into a package of cookies (virtual device). You should really build a buffer, and parse the buffer every once and a while looking for complete strings (see the previous post).
the display changes to the Input 1 without a problem. However in the diagnostics I'm getting back this:
Also, in the diagnostic options I have all of them checked but notice that there is not string from the device returned either.
Have you watched the input LEDs just to be sure?
Have you tried connecting directly from a PC and talking to it with a terminal emulator?
You may have a cable fault preventing the reply getting through, try a different cable.
The lack of a reply may explain why the module is giving you an "UNKNOWN" message.
Your fallback would be to ignore the replies from the module and just trust it to send the commands and get no reply.
Have you considered writing your own module? Try watching the strings sent to the device and ask yourself how hard it would be to send those yourself.
Thanks for your input. I will check in all of your suggestion and get back with the answers but regarding the last one, I wish I could but I'm not capable yet to do so; just yet.
OK, I tried sending commands from telnet and also from the TP in both cases I can see the lights from the display answering back to the controller so the problem is not due to a bad cable. It has to be something in the module itself.
I've had modules that didn't work for any number of reasons, because they were sending the wrong baud rate to the port for instance. It didn't seem like that big of a deal to just send the correct baud rate except for the fact that the module would just randomly send the config info back to the port.
My advice when dealing with modules is to test them out before spending too much time trying to make them work in your source code. The zip file should have a UI module and a source code that you can use with just the device to check it out.
Tony, I had both notifications for the virtual device and the actual device and all of the options were checked for both of them.
OK Tony, Let me start from the end first. Yes, I tried the module alone first and it worked rigth.
Now, to the first part. The module is executing properly any commands I need; the problem that I'm having is trying to retrieve the status of the input. The way the actual module works for this is using a couple of variables which by the way goes way over my head:
Here is what I tried:
Now for some reason the value that nTVInput is getting is not a good value. When I send a send_command vdvtv, "'INPUT-INPUT,1'"( change to input 1), or any other change input command this is what I get on the diagnostics:
Remember that I'm a newbie that have only been to programer I, so my experience is very limited. All kind of suggestions that my look pretty obvious to you, are more than welcome.
