MVP-TPS - RJ45 Plug
Hi everybody,
does anybody knows about the RJ45 plug between the two USB and the power plug?
I think it's a network plug but I found nothing about it...
Any idees?
Greetings from
MasterReboot
Any idees?
Greetings from
MasterReboot
Hmmm...
Kevin D.
I thought about it, and it would be SUPER handy, in case the Wifi crashes out, you would still be able to use the wired RJ45 connection
Plus how would it connect through the TDS? Through the pins? They're not all that reliable for charging the darn thing.
What they could do, which would be sort of cool and stealthy is have the TDS play dual roles, a charging base and an access point. If that were the case and they had somone like Cisco System do the design and OEM the hardware, this could be a good thing.
Alas we may never know!
well, not so much the Wifi of the panel lock up, but more of a WAP locking up. Big companies tend to change their wifi encryption from time to time which renders a wireless touchpanel useless.
But indeed, the pins on the TDS aren't that reliable so that't a no-go...
again, using the "crappy" docking station pins?
I can't imagine, myself. OK ... two for power, two for data, maybe another two as a closure to show it's docked, though that could be done with one since the magnet is obviously part of that ... but what are the rest of them? Separate mouse and keyboard connectors?
Is it my eyes, or does your ACE Programmers image have 4's for A, 3's for E and 1's for I.
Kevin D.
