NI-2000 POST sequence
in AMX Hardware
I have an NI-2000 that WAS working just fine. We had to shut it down and move it. When we turned everything back on, I tripped over the power cord while the NI-2000 was going through its boot up process. Now it will not boot all. Instead, it just sits there with the Output light steady on. I can't get it to respond to anything. What in the world could I have done to it? Is it totally screwed?
(b) If you have just reinstalled a working system and now the output light is on constantly I'd guess one of the cables is wrongly installed and the code is desperately trying to get in touch with some box that isn't there. Is one of the serial transmit LEDs also on?
Ryan
