Messed up TPD4 setup pages
I recently saved a tpd4 panel file from mvp 8400 to cv7 and after some tweaking to make my user pages look fine, installed the panel on site.
When I started to configure it I discovered the setup page button were all a bit skewy.
I have tried downloading the file with a full transfer - no change.
I have used the new rev of TPD4 and also done a full transfer, but still it looks like the attached file.
It looks like this in g4 panel preview too.
Can't seem to fix it, but will try resaving as different panel type and see if it goes away.
<* edit.. should all read cv10 not seven *>
Another small issue with TP4?!?
I'll do another set of tests when I have a bit more time and see if I can replicate it.
I'll have a crack at it too - when I get off site - and post some more results.
I know the 'connection ball' is always used - but I'm quite sure this won't matter.
We used to include the REBOOT button (affectionately renamed RE-CONNECT for the client) way back when the wireless panel firmware had some issues with re-establishing coms with the master under some circumstances.
I have a feeling this *was* an exact copy of the reboot button which is the same button design as the others on the setup page. Although the CV10 doesn't need this button like the MVP did, perhaps there is reference to it in the resource manager still.
