Java VNC client?
Is there any Java based VNC client that works with the AMX Touch Panels? I need to be able to access the panels from a Mac and so far nothing I have tried has been able to actually display the panel. RealVNC for Windows and the AMX ActiveX control are the only VNC clients that will actually display the panel upon connecting.
Here are some links to doc's on TightVNC's site:
TightVNC Java Viewer version 1.3.9
and the download is here:
TightVNC
--John
Ryan
That's interesting. Both of my MVP 8400s (firmware 2.70.8) never display a window or anything under Chicken of the VNC. This is the exact same behavior as everything else.
--John
Definitely not any of the above. I am the "client" in this case. I'm on the same network as all of the panels (well actually 4 of them are on the other end of a T1 line, but they give the exact same behavior as everything else). Also, I'm 99% certain it's not a network issue as both TightVNC and RealVNC under Windows can connect just fine using the native clients. Neither one can connect using their Java clients though, and I've found nothing under Mac OS X that can connect to any of my panels.
